A day in the life...
Re: A day in the life...
nope, didn't have any to put in there. iv heard the difference with and without it when the enclosures cause a hollow ecoy sound. it helps silence that. but these aren't doing that. with these it sounds like the low end just isn't there. hmmm... kinda tempted to stick a towel in there and see if it makes a difference.
Some wool stuff like this works well...
Do not use rock- or glass wool insulation material.
It lacks physical strength and will disintegrate due to the sound waves.
Closed (non vented) cabinets can be stuffed entirely.
This "fools" the driver to assume a larger volume.
i was having a bad day until i saw this
Man, talk about breaking the 4th wall :)
Took the KLEIN out for a spin after quite a while...
Only to find both down shift levers not working properly. :?
First assumption was some internals may have worn out...
But a closer look revealed cracked casings... :(
They are Shimano Deore XT ST-M750 units and considered vintage (and rare?) nowadays I guess.
Hopefully I'm able to dig up some replacements. Fingers crossed...
Maddel wrote: July 9th, 2022, 2:15 pm Took the KLEIN out for a spin after quite a while...
I did the same thing with the Cannondale. I pulled it out and tried to get it able to ride and took it out for it's first run only to end up walking 5 miles back to Bog while carrying it. Seems I forgot that the rear axle was stripped and that's the reason I parked it :shock: :shock: :shock:
Tubeless setup had also failed so I replaced the axle and used some locktite on it then put some tubes in it. It did fine mostly on the second ride.
Maddel wrote: July 9th, 2022, 2:15 pm They are Shimano Deore XT ST-M750 units and considered vintage (and rare?) nowadays I guess.
Are both shifters broken or just one? That's a 3x9 setup, correct?
schwim wrote: July 9th, 2022, 3:13 pmAre both shifters broken or just one? That's a 3x9 setup, correct?
Yes, a 3x9 setup.
Both down shifters are not working.
The funny (dorky) part:
The KLEIN resides at my parents home.
I hadn't my glasses at hand while examine the units and didn't recognize
the cracked casing before watching the pics on the computer at home. :D
So one shifter is definitely cracked. I have to check the other one again
(with some visual aid). :lol:
I already found a NOS nine fold unit for 60 EUR. 8-)
so this happened this morning :shock:
Was tired of the aftermarket carpet floor mats.
Replaced them with new original style rubber ones.
"Feels" and looks way better IMHO...
